fla-gypsy
May 21, 2013Explorer
Re: Trailer Wheel Ratings?
Conventional wisdom is the rating is stamped on the wheel on the back side or under the tire. I have not found mine so I suspect it is under the tire. Even if your wheels are only rated for 65 psi (D's-likely) taking them a few pound over should not pose a serious risk. The "E's" are rated at 80 psi and can carry a lot more weight. I have considered upgrading to "E's" on my next purchase for the reserve capacity and running them at 80 psi.
