NiteMixr's avatar
NiteMixr
RE-winterizing??
I didn't get a chance to use my camper this year, should I re-winterize it? Does the anti freeze go bad after a year?
Thanks, Rick
  • Make sure there is some red stuff in the toilet on top of the slider. It keeps the rubber gasket lubed.
  • I doubt that it would evaporate like water, but just to be safe, pour a little down each drain. JMO
  • Hi,
    I was thinking more about any smells from the empty waste tanks--if the traps have nothing in them.
  • Nothing needed. Antifreeze doesn't freeze and if the antifreeze has evaporated - air doesn't freeze.
  • Hi,
    You might want to add antifreeze to the traps. Other than that it will be fine.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
