Zigpep's avatar
Zigpep
Ready brake, ready brute
Hello, we are new to rv lifestyle and have used our class c BT cruiser twice already. We are now ready to start trying to set it up for towing. We are going to have to change our class 2 hitch to a class 3 then will need a system. The prior owner gave us a system called a ready brute and a ready brake, company is based out of Kansas. When I asked the local shop that installs towing systems he had never heard of it and his remark was "interesting" when he looked it up. Anyone ever heard of it and is it safe? It would be great not to have to pay 1500.00 for a new system but want to make sure we are safe. We will be towing a Jeep Wrangler 4 down.
Thanks
  • I used one for four years, until we sold the MH and the Towed. I would not consider another system. The Ready Brake is simple, safe, reliable, easy to connect, does not interfere with normal operation of the Towed. The cost is considerably less than other systems I considered. I would recommend it.
  • IMO (and it IS only my opinion) the ReadyBrute/ReadyBrake system is the ONLY practical auxiliary braking system for towed motor vehicles.
    It is simple, completely mechanical, relatively inexpensive, easy to install, does not require installation and removal like some of the electronic boxes, has never been accused (to the best of my limited knowledge) of burning up the towed vehicle brakes, has never (again, to the best of my knowledge) failed in the middle of a trip, and it simply does the job for which it was designed.
    I would recommend that if the system you have does not have the breakaway feature, it would be a good idea to get it. Why have the braking without the breakaway, it doesn't make much sense, IMO.
    Many people don't give any thought to the capacity of the safety chains or cables. Please do make sure that they have a working capacity that will tow your towed vehicle in the unlikely event the hitch should fail. The cables or chains should at least have the same capacity as the towbar.
  • Been using one for 6 years towing a Rav 4. Easy set up and no problems so far.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Nov 28, 2025
