willald's avatar
willald
Explorer II
Apr 29, 2013
Readybrake may not be an option. What to do..
...We've been flat-towing DW's car (Kia Sedona van) for a year now, using the ReadyBrute Elite tow bar with integrated ReadyBrake system. Has worked great, and I've said numerous times when this subject comes up, ReadyBrake is just about the only system I'll have, for several reasons. You just can't beat its simplicity, cost, and the fact it simply works, period.
Anyway, we recently traded my daily driver for a 2013 Ford Fusion Hybrid, and are in the process of setting it up to tow behind our MH as well. We want to have the option to tow either of them, and actually prefer towing the Fusion, as it is simpler, less trouble prone (no lube pump to deal with like the van has), and much more fun to drive. :)
Wiring and base plates are done on the Fusion. Had to wire a 2nd 6-round plug on back of MH for the Fusion since it needs a charge wire (and does not use lube pump like our van), but that was easy enough to do. Now, time to get supplemental braking set up.
Obviously, my plan is/was to order a 2nd ReadyBrake cable (just the cable that goes on the car) and install it and a 'ReadyStop' breakaway setup on the Fusion.
However, I just got some really bad news, that I still don't want to believe: Brought the Fusion to RV dealer (same one that installed ReadyBrake on our van), had him look the Fusion over to see if ReadyBrake can be installed on it. He says, no can do. Steering column placement, as well as general design of the firewall make it impossible. Waaaaaah! :(
Anyway, I'm working now on getting a '2nd opinion' from another dealer, and have a '3rd opinion' possibility as well I may pursue. I'm a bit suspicious that the technician I talked to first simply did NOT want to do the Readybrake install since it would be a bit more difficult, or maybe was trying to 'encourage' me to spend a ton more $$ with them on one of the 'magic electric box' type systems - RVi, SMI, Invisibrake, Patriot, etc.
I've already talked with ReadyBrake (Night Shift Auto) about this, but basically got no answers from them. They *claim* it should work, and that they have customers with 2013 Ford Fusions using their product. They could not give any more specifics than that, though, other than to point me to some of their dealers/installers in this area. I've contacted those dealers, they couldn't provide any information, either (although one is still looking into it). Thinking about taking the DVD, instructions, etc. for Readybrake to the Ford dealer, and see if they'd be willing to install it (thoughts?)
It absolutely makes me SICK, the thought of having to spend $1k or more and have two different braking systems (one for each vehicle). Especially since I really want nothing to do with the 'magic electric box' type systems. Would almost rather do without supplemental braking with the Fusion entirely, than to get one of those systems, haha!
Sooooo, my question is this: Is there ANYONE, ANYWHERE out there towing a Ford Fusion hybrid, that installed a ReadyBrake system on it? If so, please PM or respond here, I'd love to know just how it was done, where the cable was run through the firewall, etc. It seems like it could be done by running the cable just to the side of the brake pedal arm (same way it was done on our van), but not real sure.
Second question: To those like me, that prefer the Readybrake for its simplicity and really don't want any other system: If you were forced to either buy another system or do without toad braking, which would you do? What system would you get, if any, if Readybrake was simply not an option?
Oh, and before anyone starts down this path: I've read (and read, and read, LOL) all the threads 'debating' about why supplemental brake systems are or are not necessary. Please, lets not let this turn into one of those debates. :)
  • rjstractor wrote:
    Routing issues for the cable aside, have you looked into the possible issue of the hybrid's active braking system causing problems with the ReadyBrake? When I looked into installing a system in my Escape Hybrid my research indicated that I would need to go with one of the electronic systems with a pressure reducer. Maybe the Fusion has a way to disable active braking prior to towing.
    Yes, and that is not an issue at all. Its actually the exact opposite - Active braking is one of the reasons to stay with Readybrake, as its operation is not really affected by whether or not you have active braking on all the time, vacuum assist, or just a 'dead pedal'.
    Since the Readybrake is basically a surge based system, it only activates the brakes until the toad is no longer 'pushing' on the MH enough to activate the brake. Having active braking like a hybrid does, only means that Readybrake won't have to pull as hard on the peda, before the car is slowed enough to release the actuator arm and the toad's brake pedal.
    If I am forced to go to a 'magic electric box' type brake system instead of Readybrake, then, yes, the Hybrid's active braking becomes an issue, and I'd have to take that into consideration, in which system I went with.
    I'm really, really hoping it doesnt come to that, though. LOL, those other brake systems cost soooo much, I'd be $$ ahead installing the Readybrake, even if I had to pay for a good 8 or 9 hours of technician labor to install it, haha. :)
    Will
  • Routing issues for the cable aside, have you looked into the possible issue of the hybrid's active braking system causing problems with the ReadyBrake? When I looked into installing a system in my Escape Hybrid my research indicated that I would need to go with one of the electronic systems with a pressure reducer. Maybe the Fusion has a way to disable active braking prior to towing.
  • Bobbo's avatar
    Bobbo
    Explorer III
    I am like you, I like the ReadyBrute Elite, but I would consider the SMI Brake Stay In Play Duo.
  • Community Alumni's avatar
    Community Alumni
    Get a BrakeBuddy. It'll work on both cars without having to do any alterations on the vehicles.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 11, 2026
