RCMAN46
Nov 29, 2013Explorer
Changing the rear end ratio will not give the truck any more horsepower than it has now period!
If you have a newer truck with a six speed transmission changing the rear end ratio may change the gear you can climb a hill but most likely it will be at the same speed as before the change. Horsepower is what gets you up the hill and a different rear gear ratio will not change the horsepower an engine can produce.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
