2stroked
Nov 29, 2013Explorer
SoCalDesertRider wrote:
I would go with 4.88's. I went from 3.55 to 4.56 in my F350 with a 351 and I wish I had gone with 4.88's instead. Only reason I stopped at 4.56 is my truck has a C6 auto, which doesn't have an overdrive gear. If it had the ZF 5speed or E40D 4speed, both of which have overdrive, I would have gone with 4.88's in a new york minute!
I'm also going to change to my other F350 with 7.3 diesel and E4OD from 4.10 to 4.56, at some time in the future.
Might be overkill going 4:88, wish there was a way to try the different ratios, I will go to a bigger tire if I keep the truck 285 from a 265/75 17 which will make the gearing a bit taller
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
