RCMAN46
Dec 01, 2013Explorer
SoCalDesertRider wrote:RCMAN46 wrote:Gearing is a torque multiplier. Lower ratio gearing (higher number, ie: 4.56) greatly increases torque available at the rear wheels, versus higher ratio gearing (ie: 3.55).
Changing the rear end ratio will not give the truck any more horsepower than it has now period!
If you have a newer truck with a six speed transmission changing the rear end ratio may change the gear you can climb a hill but most likely it will be at the same speed as before the change. Horsepower is what gets you up the hill and a different rear gear ratio will not change the horsepower an engine can produce.
400 lb-ft torque x 3.55 = 1420 lb-ft at the rear wheels
400 lb-ft torque x 4.56 = 1824 lb-ft at the rear wheels
Lower ratio gearing also increases the rpm of the engine, at the same wheel speed. Most gas engines produce more horsepower at higher rpms. So yes, lower ratio gearing does increase the amount of available horsepower and torque at the rear wheels, at the same wheel speed, compared to higher ratio gearing.
You have neglected what a transmission does. If I want to increase the rpm of an engine to get into the peak horsepower range I simply go to a lower gear. I do not need to spend money on a rear end gear change. The modern 6 speed transmissions give all the gearing you will ever need for most highway towing.
And the 5.3 engine will not stress the drive-line system regardless of what rear end gear is used. It simply does not have enough horsepower to do so.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
