Turtle_n_Peeps
Dec 26, 2013Explorer
rubsal70 wrote:
I am too interested what op did. I am in the same boat. Thanks
The bottom line is a gear change does not make horsepower. Sometime a gear change can put the engine in a better RPM band when it's between two gears............but sometimes it might make it worse also.
What I'm trying to tell you is if you want to go up a hill faster, a gear change won't make it any better. If it does, it will only make it a few seconds faster. If you want to go up the hill a lot faster then you need more horsepower.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
