bowler1's avatar
bowler1
Rear End Sag with Tundra Suspension Leveling Kit???
I bought a new truck--a 2012 Toyota Tundra. After buying it, I realized that it had a front end leveling kit--a front end lift that is intended to raise the front of the truck to be the same height as the rear and eliminate the rear end rise that is designed into a truck.
So the problem is that the rear end rise of the truck is intended to compensate for a load so that your rear end does not sit lower than your front. That concnered me a bit.
So I just got my WDH adjusted right and indeed, the rear end of the truck sits about an inch lower than the front with the trailer hooked up. (this is with the trailer loaded up with all but water--not sure how a full tank of water would affect it)
Should I be concerned about this?
If so, I am thinking that adding air bags to the rear may help to fix this problem. What do you think?
thanks
Matt
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 21, 2026
