bowler1's avatar
bowler1
Rear End Sag with Tundra Suspension Leveling Kit???
I bought a new truck--a 2012 Toyota Tundra. After buying it, I realized that it had a front end leveling kit--a front end lift that is intended to raise the front of the truck to be the same height as the rear and eliminate the rear end rise that is designed into a truck.
So the problem is that the rear end rise of the truck is intended to compensate for a load so that your rear end does not sit lower than your front. That concnered me a bit.
So I just got my WDH adjusted right and indeed, the rear end of the truck sits about an inch lower than the front with the trailer hooked up. (this is with the trailer loaded up with all but water--not sure how a full tank of water would affect it)
Should I be concerned about this?
If so, I am thinking that adding air bags to the rear may help to fix this problem. What do you think?
thanks
Matt
  • Over compensating for the lift by increasing the tension on the hitch is not a good solution.
    My dealer recommended the option of just adding a 1 or 1.5 inch block under the leaf springs in the rear in order to bring the rear up a bit. He thought that air bags might make a rough ride.
    ^This would be the easiest and cheapest solution with the least affect on towing, especially if you like the lifted look. I have 2.5" lift on the front and put 1" blocks on the rear to keep the rake. It had no affect on towing. If you look at most HD trucks these days, they come from the factory with rear lift blocks.
    Airbags will stiffen the suspension and can make for a rough ride when unloaded. The rubber bags are really stiff and you need to maintain a minimum of 5psi in them. The double bellow style seem to be more forgiving than the singles.
  • I personally think air bags are the devil for towing a trailer large enough that requires a WDH. Remove the front lift.
  • I ended up taking off the leveling kit. It tows much better now. However...when I got the leveling kit taken off they discovered that there was also a 1 inch block in the rear. I did not take that off yet. Wanted to see how it did with it still on there.
    So right now I have it stock in the front and still have the 1 inch blocks in the rear.
    I am probably going to get rid of the blocks too.
    The truck rides much better without the leveling kit. Anyone who says they do not affect ride quality is wrong.
    matt
  • If towing is better and ride is better, I would leave the rear blocks alone.
  • If it were mine, I would put both ends back to stock height, and then work out details and mods, if needed, from that starting point. Factory engineers are usually pretty smart dudes.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 17, 2025
