BGummer's avatar
BGummer
Receiver hitch won't latch. Help!
Hi,
Hoping someone can help. I have had this trailer a month or so with no prior issues. But went to hook up tonight and I can't get the hitch to latch. It sets down on the ball fine. The latch actually goes down to. But the latch is too far forward to latch into the grooves to lock into place. The pin therefore won't line up either. It looks as if the latch is just too short. But it has worked fine in the past. What am I missing?
I will attempt to attach pics.
Any help is much appreciated!
  • Tvov's avatar
    Tvov
    Explorer II
    Is the hitch all the way down on the ball? Meaning, is your tongue jack retracted all the way? When in a rush I've tried to lock the hitch without having the tongue jack all the way up, basically while I'm still retracting the jack. If the jack is touching the ground (or wood spacer under it, however you do it), it may be holding up the tongue more than you think.
  • mich800 wrote:
    I cannot really picture what you are talking about. But try this. When the hitch is sitting on the ball, get in your vehicle and cycle it through drive, reverse and back to park. Maybe it is in a bind.
    I can't really picture what the problem is either. I sometimes have to move my truck an inch or so forward or backward to get mine to latch or unlatch. Sometimes just releasing the parking park will allow it to move enough to release/latch.
  • I cannot really picture what you are talking about. But try this. When the hitch is sitting on the ball, get in your vehicle and cycle it through drive, reverse and back to park. Maybe it is in a bind.
  • BGummer wrote:
    Hi,
    Can't figure out how to get pic uploaded from phone.
    It looks like everything underneath is in place and ball is tight. Must he something stuck......tried soaking in wd40.
Looking for advice before your next adventure? Look no further.25,143 PostsLatest Activity: Jun 23, 2025
