tmaxx's avatar
tmaxx
Reinforcing frame extensions for additional 300lbs towing.
I am in the process of purchasing a 2003 Monaco (McKenzie) Rogue 20' RV with two slides and the Ford V10 E450 chasis. The hitch is rated for 3500lbs. We want to tow our 2010 Ford Fusion Hybrid which is spec'd at 3800lbs. I know the Ford engine can pull the 5000lbs, but I am unsure about the chasis and hitch. On the Class C forum, someone suggested reinforcing the frame extensions to get the additional towing margin. Are there some guidelines on how to do this? If I go to a weld shop, would they know how to get this done?
Also, would I need to replace the current hitch, rated at 3500lbs with a 5000lb hitch?
Thanks.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 05, 2026
