BlackSilver's avatar
BlackSilver
Remote thermostat
For you snowbirds who have "remote controlled thermostats", what do you use? What are the things you like, AND the things that you don't like about your model?
I'm thinking about leaving my DSL/Internet link in place this winter, and installing a thermostat with remote control.
I "must have" the following minimum features:
-- alert if the house temperature drops below a predetermined temperature (45-degrees?)
-- ability to check current temp from my smart phone or tablet.
-- ability to adjust temperature from my smart phone or tablet.
-- no monthly fees (other than having to keep my DSL active)
Other nice to have, but not deal breaker features:
-- alert if the house temperature rises above a predetermined temperature (80 degrees?)
-- display outdoor temperature
-- ability to tie in other sensors/cameras/whatever
Right now I'm leaning toward a couple of Honeywell "WiFi Smart thermostat" models which cover all of my "must have" features. Cost around $200.
Comments/recommendations?
  • eric1514 wrote:
    BlackSilver wrote:
    Turns out the Honeywells all require a "C" wire which my system does not have.
    Any other candidates besides nest?
    Use the Venstar Add-a-Wire. Here's a video
    Venstar Add-a-Wire installation
    Just pull another thermostat wire with enough wires or leave old one on wall & move new one to a location you can get to.
    Before retiring Me & my employees installed over 100 of the Honeywells with no issues & several of the Carrier OEM thermostat that came out as I was retiring.
    I don't have the C wire either but my Honneywell works just fine. They have work arounds for that sort of thing. You have to set it up on the furnace end by jumpering another wire. The result is that it works fine, but you have no manual control of the fan anymore it's always in Auto fan.
  • Turns out the Honeywells all require a "C" wire which my system does not have.
  • I am in my house right now with a Nest Thermostat. After some initial issues when it was originally installed (on an older existing furnace) it seemed to work fine for about 4 months (until mid March this year). I was still in Florida when it stopped transmitting local weather conditions at home. I have worked with Nest tech support since then and although they tell me it's a software issue.. it is still not resolved. Now that my furnace season has started again it is giving me incorrect readings of weather conditions here at home and just in the last couple of days it is screwing up the 'history' screen which shows that the furnace has been running all day every day... but I'm here and I know it's not!! So I'm with sch911 above! My next one will be a Honeywell!!
  • I use an older Honeywell which has those features (they all pretty much do if WiFi enabled).
    But the Lyric ($150) is the one I'll be upgrading to:
    Honeywell Lyric
Looking for advice before your next adventure? Look no further.25,106 PostsLatest Activity: Jan 25, 2025
