monkey44's avatar
monkey44
Nomad II
Mar 05, 2014
removing tailgate - 2015 GM trucks w/BU-Camera
What a hassle - removing the tailgate means removing the plug to the BU camera - which is under the bed and beside the frame in a three plug connector which you have to "guess which one" first ... and then become a contortionist to reach and pull it. And, you need to be strong enough to do fingertip-pushups as well, because I could not pull it out.
And, it's almost impossible to reach without rolling under the bed... a very poor design .. each time you remove the TG, all this PITA ...
The plug requires a screwdriver to clip the pin safety off as well.
I would think if you need to remove something, it would be at least accessible. Very strange ...
  • They're already selling 2015 models?
    I know on my Ford, it's easiest if I drop the tailgate, pull it out and set it on a couple of saw horses. Then I can easily reach the plug.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
