roadtrek_in_DC's avatar
Jul 20, 2019
Renting out your RV nightmares.
Hello,
Having only using my RV for twice a year for a week at a time. I found myself leaving my RV in the parking lot most of the year. I started renting out my RV. The experience wasn't as bad as I had thought but it is coming back each time with little more damage than I anticipated.
The last damage took out the under the vehicle's plumbing. Already spent $350 replacing a some plumbing and now the shop is telling me the black tank is damaged.
It is all covered by the insurance but the shop is telling me the replacement tank cannot be found due to Roadtrek going out of business early this year and the manufacturer also stop making the black tank for 2012 Roadtrek 190. The shop is looking in to other tank that might fit but the vehicle's low clearance is making it difficult to find an alternative. He also tells me the junk yard also does not have this particular model to pull a used tank.
I'm potentially looking at a RV without a black tank and the frustration is that it can't be fixed.
The insurance says they can only cover up to the damage and no more.
Does anyone have any suggestion?
The shop did say I can put in a compost toilet but I need a black tank.
  • A friend of mine does repairs on boats hulls both fibreglass and poly vinyl(?);
    Take the tank out, take it to a boat shop and get their opinion.
    They should be able to help you out.
  • wonder if your repair guy is just not all that motivated to finding a repair tank. I would ask what the damage is. If it's not affecting the drain hole then remove the tank and have it plastic welded. Or they can measure the existing tank, and find a replacement the same size or fairly close to put in. they might have to modify or build a new tank support. But I would think a competent shop should be able to handle that.
    Here's the first two hits I got off a search.
    Plasti-Mart.com
    PlasticWaterTanks.com
  • Maybe the black tank can be repaired? It doesn't have to be pretty, just leak free.
    Possibly your shop does not want to mess around repairing the tank.
    If you cannot find a replacement tank, I would look into plastic welding, glue, tape, J-B Weld or anything that can repair the black tank. It's worth trying.
    Your damaged black tank reminds me of an old joke I read on the forum.
    Q: what's the difference between a rental RV and an ATV?
    A: the rental RV can go anywhere.
  • and start googling 'RV Salvage Yards' for your part. try Colaw RV Salvage in Carthage MO. and either stop renting your RV (best choice) or drastically increase your security deposit.
  • Probably a bit late, but my recommendation is to stop renting out your expensive vehicle......to people who don't know how to properly operate it.....
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 05, 2025
