CALandLIN
May 31, 2018Explorer
Magnum40 wrote:
Howdy, My trailer came with 4 of the Maxxis M8008 D load range tires. One went flat last wknd coming out of the mountains due to a rock and can't be repaired. Any issue with replacing it with the same tire but the E load range model? It's only $15 more and I don't know why it wouldn't be okay. Any reasons not too and stay with D's? Eventually I would get all E's hoping they offer better protection against rocks. I camp way up and the last mile is 4 low up and down.
The same rule applies as if changing any single tire, except axle position. On RV axles they all react the same so you can just use the LRE on any axle with the LRD, as long as they have the same size designation and construction (Bias/Radial). All tires on the same axle must be inflated to the same PSI.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 29, 2026
