- Bill1374ExplorerHad a board problem with a Norcold last winter while in Florida. Because I was under warranty, mobile repair had to jump through hoops to get a new board. After it was installed, still no fried. A call to Norcold disclosed that you had to do a reboot to get the board working.
I suspect this may be the same issue for you. A call to Dinosaur should clear it up. - Mandalay_ParrExplorerMake sure the 12v polarity is correct. Do you have 120v?
- JanssExplorer IIIn my vague memory, I had a similar issue a few years ago with a replacement Dinosaur board. I called Dinosaur and the guy walked me through a sort of reboot of the board, which involved something like removing a certain fuse and a few other steps, then re-inserting the fuse. So I suggest calling them if you can't figure it out.
- nomad297ExplorerCheck the 12 volt fuse for the refrigerator.
Bruce - bob213ExplorerCheck the fuses on the new board.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
