BruceMc
May 14, 2022Explorer III
BTW, the sound is much better than the Jensen. I had replaced the interior $15 Jensen speakers with a nice set of $200 Yamahas, as stated in my original post. The outside speakers were always muted, while the Jensen over-drove the interior speakers to the point of making them buzz at the peaks. The iRV drives both fairly equally, and the sound from the Yamahas is very pleasant.
Pairing with the phone is simple - select BT, and look for the iRV on the bluetooth list on the phone. Tap, and you are connected. The Jensen took a 12 step program, then would forget the pair in a day or three. I gave up.
The physical build quality of both the Jensen JWM6A and the 32" TV is very good, but the electronics and software rates far below physical build quality.
The iRV is not near as well built, as the silkscreening on some buttons are a bit crooked; the issues I had with the fascia as mentioned, and the rear power and speaker connectors were sub-par. After I mated them for the bench test, it took quite a bit of work to extract them, and that was with tools. The metal opening around the connectors was too small to allow the latch to fully unlatch. After coaxing them out, I snipped the tips of the catches so they could be extracted without issue in the future. The HDMI and antenna connections were fine.
The only Jensen product remaining is the in-dash double din, that failed a little over a year after we purchased the Sunseeker. I rarely used it anyway, the GPS map was very hard to read, as if someone designed the graphics on a 40" monitor, then didn't consider visibility on a 6" screen. It occasionally has a windows error pop up, so I understood the issue; it was based on some embedded windows OS. Probably CE.
(Remember windows ME, and NT? We used to combine the three - CE-ME-NT)
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
