JimK-NY
Aug 04, 2019Explorer II
Just a few points to consider:
There are a lot of cheap LED bulbs available. Spend a bit more and buy bulbs that are rated for up to 15 volts or so. LED trailer lights, and Superbright are two websites that carry quality bulbs.
Any LED bulb can interfere with radio reception. I have not figured out why or any pattern that explains this. I have changed bulbs of the same brand and seen the issue come and go.
Buy only a few bulbs at first and decide the temperature range you like. A bulb with an output of around 3000K will duplicate old incandescent bulbs and will give a yellow tint to everything. I liked that for a while because I was used to it. Now I have changed over to bulbs that are around 5000K. That is closer to sunlight and a cleaner look. Now everything just seems to look dingy with the warm bulbs.
Consider replacing the fixtures instead of just changing to LED bulbs. The fixtures are inexpensive and have easier to use switches than my old fixtures.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: May 12, 2019
