ol_Bombero-JC
Jul 02, 2017Explorer
alfredmay wrote:
Buy the entire assembly. Many times the cable is OK but dirt and crud have entered the cable sheath and cause binding.
Many times the cable is *NOT* OK........
It's not expensive to replace the whole works - however, usually the cable is the culprit due to the lousy job the factory does with the routing (check for radical bends which cause kinks).
Been there, done that - first - try replacing just the cable and brackets, make sure the "run" is good for freedom of movement.
Depending on access to the valve, saves lots of unnecessary grief!
:C
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
