DSDP_Don
Apr 19, 2016Explorer
Pretty simple to make. Build some wood frames, add a little swoop to the top piece for design and then do as "NYCgrrl" suggested. Once they're done, add some "L" brackets on the inside to mount to wall. Most of the manufacturers use two washers welded together at a right angle instead of the "L" brackets.
Sounds like a fun project. If you can afford it, add some MCD shades to make a nice update. If you do, make sure the new valances are at least 4" deep to fit the shades. Do a few at a time.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
