poppin_fresh's avatar
poppin_fresh
replacing kitchen faucet?
Just curious,
Has anyone replaced the kitchen faucet in their RV? Is it residential-ish in size and hole placement?
My small camper has a 60/40 split sink, but the faucet is offset to the right side so it barely reaches the left bowl. I would love to replace it with a pull out style faucet if it's feasible.
thanks!
  • Replaced both kitchen and bathroom sink faucets with residential MOEN Brand faucets that GF picked out.
    Straight replacement.......no hose adapters needed
  • I replaced mine with THIS it is a plug and play.easy to do with no adapters needed.
    Others will suggest a regular house one from HD or Lowes,but in most cases you have to use extra fittings to adapt to the lines in the RV, this one is made for a RV and will just bolt up.
    The pull out is a great feature and very useful.
  • Measure the distance between the knobs if equipped or holes in sink. Residential are 8 inches on center.
  • Not an issue, we replaced ours with a regular residential faucet. You're good to go. We had the same issue and put in a longer reach faucet.
Looking for advice before your next adventure? Look no further.25,130 PostsLatest Activity: May 04, 2025
