Dirtbags77
May 04, 2013Explorer
I have replaced a couple on my Mh. After you take off the old seal make sure you clean off the old surface real good then wipe it down with alcohol so it is clean and dry. I used contact cement and follow the directions on the can. They have held up good over a year and no leaks that I know of. Good luck.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 20, 2026
