Ernest's avatar
Ernest
RidEx for Black & Gray Tanks
I've noticed a lot of holding tank (Black & Grey) threads over the last few months.
RidEx is about the best and safest thing in the world for cleaning the tanks and sensors. It is campground friendly;it is mean for septic systems.
I use it by filling my tank(s) half way and adding a few oz. then letting them sit. The warmer the better. If we traveling 2-3 months I use it between campgrounds.
If you want to see how well it does just drain your tank before you use them and you'd be surprised at what comes out.
You can get it at Lowes Walmart and Home Depot for sure.
Just an FYI
  • I have used Ridx over 16 winters at my winter spot that dumps into a septic system. It works very well but it never has cleaned the sensors as they have always showed Full when empty or not.
    I dump the black tank every 14 days needed or not. Gray is open until 2 days before dumping the black.
  • sammytoo wrote:
    korbe wrote:
    It appears to be full of bacteria that would aid in breaking down the solids in a septic tank. But it cleans the RV tank and sensors as well? I personally don't think I need to start the solids breakdown process while sitting in my holding tanks.
    You really do want to start that process in your tanks. All the particles that cling to the bottom and sides of the tank will turn to stone. The "good " bacteria in a septic cleaner will help to prevent this.
    That's my opinion also.
    I bought a 5'ver who's black valve was a slow leaker. The PO did not notice it because he was always at a FHU. The black tank was pretty much clogged, I could only go 3 days till the tank was full.
    Rid-X after dumping (so it could work for a few days) followed by a spray wand during dump time took care of the problem after half a dozen dumping's.
    I used a see thru fitting and actual chunks were being passed down the stinky slinky.
  • It appears to be full of bacteria that would aid in breaking down the solids in a septic tank. But it cleans the RV tank and sensors as well? I personally don't think I need to start the solids breakdown process while sitting in my holding tanks.
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 08, 2025
