FULLTIMEWANABE's avatar
Jul 15, 2016
ROOF REPAIR SEALANT WHICH ETERNABOND OR OTHER OPTIONS
We've been led to believe that Eternabond is likely the best option to seal all around our skylights, fans, antenna, air horns etc = basically everywhere there would likely be a leak from the roof to the inside.
Upon googling Eternabond for RV Roofs, with several options of Eternabond tapes available (looking for about 50ft) we are confused which actual one we should be ordering/using and at what width.
Also before we apply the Eternabond do we remove all the existing sealants?
Equally if there are any strong recommendations of what is better and more effective/longer term wear to seal around these items would really value your sharing.
Our roof is Royal Tuff - 2003 Southwind.
Many thanks for your sharing of sage advice and personal experiences.
FTW.
  • Eternabond Roofseal is the one that will work with most of your roof through holes. If you have things to seal that need a tape that will bend or conform to any angle, Eternabond Webseal does a good job on that. Webseal needs to be painted, Roofseal does not.
