- 3_dog_nightsExplorer
JaxDad wrote:
If the unit was used a lot in a c/g that had a well of its own, and was in an area where there's sulphur in the water, there will be a layer of sulphur-bearing silt in the bottom of the water heater.
Pull the drain plug and /or anode and use a strong stream from a garden hose directly in the tank hole. Bet a bunch of crud washes out.
Have had the problem a few times in the past, JaxDad's answer is the best solution I found. Backflush repeatadley till you smell sweet water. After that I've gotten in the habit of draining my water heater when I get home. Only take s a minute or two and no more problems. Just don't know what you are going to get in the water when traveling. That's why we drink bottled. - JaxDadExplorer IIIIf the unit was used a lot in a c/g that had a well of its own, and was in an area where there's sulphur in the water, there will be a layer of sulphur-bearing silt in the bottom of the water heater.
Pull the drain plug and /or anode and use a strong stream from a garden hose directly in the tank hole. Bet a bunch of crud washes out. - ploiselleExplorer
- MarslandExplorerI've had that happen before, usually when the water had been in there some time. A good flush or maybe a system sanitize with bleach should take care of the issue. That is of course if you don't leave water in there again for a long time. With regular use you should be okay.
- Peg_LegExplorerDoes it have a sacrificial anode?
Looking for advice before your next adventure? Look no further.25,149 PostsLatest Activity: Jul 17, 2025
