dspencer's avatar
dspencer
rubber roof question
I own a 2005 Trail Lite Batam Hybrid with the rubber roof. It is always stored inside when not in use and the roof is kept clean. I am noticing this summer that there are a hand full of what i will call bubbles on the roof. These are small bubbles, maybe golf ball size. There is no leaks or problems but this is the first time i have noticed something like this. Is this something i should be conderned about and if so what do you recommend. Any insight would be appreciated.
  • dspencer wrote:
    I am noticing this summer that there are a hand full of what i will call bubbles on the roof. These are small bubbles, maybe golf ball size. There is no leaks or problems but this is the first time i have noticed something like this. Is this something i should be concerned about and if so what do you recommend. Any insight would be appreciated.
    We have a 2012 year model it has maybe 5 bubbled spots on the roof.
    They seem to come and go.
    When I step on them they stay down.
    I figure they'll disappear as the roof ages in the sun.
    On a former coach we had a large section of the rubber roof adhesive fail on the top front (after 13 years of ownership).
    At highway speeds it used to rise up 4-5 inches in hot weather.
    I crawled up there peeled it back and re-glued it.
    It was a big hassle, yet needed to be fixed.
  • dspencer wrote:
    have met ocassionaly a 5th wheel and noticed that the roof was bubbled up huge going down the road.
    Huge is a problem, not small.
  • The rubber is not torn or punctured at all, everything is okay otherwise. I know over the years towing i have met ocassionaly a 5th wheel and noticed that the roof was bubbled up huge going down the road. I didn't think it hurt anything if there's no damage but wanted to get you guys opinion on it.
  • If the rubber isn't punctured, it will still do its job. Your main points of water ingress will be seams and cracks, not the rubber itself.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 16, 2026
