Gdlow's avatar
Gdlow
RV Checklist app
I have the Thunderbolt Android phone (Inherited from Wife :R) and I downloaded the RV checklist app...Going to the help section it says if you want to see what the CSV format is to export it...I did, but now I can't find out where it exported to...any ideas????:h
  • RedRocket204 wrote:
    bmupton wrote:
    plug in as USB drive to your PC).
    You'll find the csv file it created in the 'backup' folder.
    This.
    Ok...thanks
    Got it...thanks again:B
    This.
  • Gdlow wrote:
    bmupton wrote:
    Mine saved it to /sdcard/backup/
    I only have internal storage in the Nexus 4, so if you have an external sd card it might be slightly different, but look for a 'backup' folder.
    going into the settings...what should I look for?
    It's not in the settings of the app anywhere, you'll need to use your device's file manager (or plug in as USB drive to your PC).
  • Mine saved it to /sdcard/backup/
  • bmupton wrote:
    My guess would be in either the 'Downloads' folder of your storage, or a folder named similar to the application name.
    If you gave a link on the play store to which RV checklist app I'll install it and take a look on mine. Likely stores in the same place regardless of phone.
    Here it is..RV Checklist
  • My guess would be in either the 'Downloads' folder of your storage, or a folder named similar to the application name.
    http://en.wikipedia.org/wiki/Comma-separated_values
    It is comma separated values. That means the data is separated with commas. You export a CSV file from the APP and then you can use Excel to open CSV files.
    My problem is I can't find the file in the Android phone so that I can open it with something..I even used the cord to open in a computer...I know what csv is...just can't find the file...
Looking for advice before your next adventure? Look no further.25,180 PostsLatest Activity: Jan 23, 2026
