scout dad wrote:
Thanks for the info, I should be clear that I will using them not only during the winter but all year long. My current trailer has a roof leak, I only wanted something to help prolong the life of roof when a under covered spot.
I have used a cover every winter since I purchased my trailer and the original owner used one also. The first summer owning my trailer I found a roof leak. Had it fixed, or so I thought, came home, covered it for the winter. Checked multiple times to insure it wasn't getting wet. All good, opened it up to go camping and on the first trip, had water in the same area as before. The cover kept the trailer from getting wet. Went back to the repair shop and after a day or so, they found an area under the fridge vent that was allowing water to get in. They fixed it and haven't had water inside since. But, I check the roof constantly.
I also disagree with the comments about chafing, paint rub, etc. Make sure the cover is a good one and is tight, use the belly straps. I have a couple tears, but the cover is 6 years old now. The only real issue is the rain gutters. I just bough new ones because using the cover, I have destroyed the old ones. $10 for a new set of 4.
