Pangaea Ron wrote:
Here's an exerpt from the 2009 IPC (International Plumbing Code). It seems that hot water is required to comply with this provision. Tempered water temperature is defined as from 85F to 110F.
SECTION 607 HOT WATER SUPPLY SYSTEM
607.1 Where required. In residential occupancies, hot water shall be supplied to all plumbing fixtures and equipment utilized for bathing, washing, culinary purposes, cleansing, laundry or building maintenance. In nonresidential occupancies, hot water shall be supplied for culinary purposes, cleansing, laundry or building maintenance purposes. In nonresidential occupancies, hot water or tempered water shall be supplied for bathing and washing purposes. Tempered water shall be supplied through a water temperature limiting device that conforms to ASSE 1070 and shall limit the tempered water to a maximum of 110ºF (43ºC). This provision shall not supersede the requirement for protective shower valves in accordance with Section 424.3.
I don't think anyone is saying they shouldn't have hot water. But if the hot water system is broken, what, exactly should they do? We have no idea what the problem is. Could be the heater failed, could be a gas line was severed somewhere and gas is not available until the line is repaired. Could be a valve failed, who knows
I can't believe that failure of a system would be a violation of plumbing code, section 607 or any other code, section or whatever. Failures happen and it surely isn't a code violation. As for the timeframe of repairs, it's a holiday weekend. If parts need to be shipped in, that is an issue. Just finding a qualified repair person might be problematic, especially if it requires a boiler worker. Sometimes there is a gap between failure and repair that cannot be bridged. Even though it is a shower and restroom facility, I don't think there is anyone who can go in and just poop out the repair parts.
