Bergy464's avatar
Bergy464
RV toilet question
I have a 2009 KZ camper with a "aqua-magic style plus" toilet. My issue is upon pressing the flush pedal the gate opens immediately with the water flowing shortly after. I've looked at different things with the toilet and can't seem to find a way to have the water run without the gate opening.
Anybody have insight into this toilet and getting water to flow into the toilet without opening the gate?
Thanks in advance.
  • I guess I wasn't clear enough. I've watched the videos, read the manuals, done all that. Lifted up, down half way, barely, everything, dug around on it and can't seem to find a way to adjust. LadyRVer, I wonder if I have similar issue/model line, kinda sucks.
    Was curious if anyone had that same model as me and knows how to adjust if possible.
    Thanks again.
  • Mine does the same thing as OP. No midway point to add water. First one to not have the add water feature.
  • On one pedal toilets, they work in a couple ways.
    1. With your toe, lift the pedal up. This lets water in. Then after you get water in, press the pedal down and dump and it will begin flowing water in a second.
    2. Barely push the pedal and it will start the water. Push harder and the valve will open with the water running.
    My current TT falls under category #2. My first Camper, back in 2006, used #1 method above.
  • Likely lifting the pedal instead of depressing it. That was my experience with a similar toilet.
    We also take a squirt bottle filled with water to clean up if there is skid marks... Fun to practice harmless shooting.
