aruba's avatar
aruba
RVQ regulator
Hi,
My RVQ has the following hose with the regulator as pictured:
If I am attaching the RVQ with the hose above to a 20lb propane tank, is it still necessary to have the regulator as pictured below?
Thanks!
1 Reply
  • Community Alumni's avatar
    Community Alumni
    Not applicable
    There should only be one regulator, either mounted on the grill or on the hose as per your photo. If your RVQ has the regulator on the hose only, then the 20# adapter hose in the photo should be correct for your unit.
    On my Q200, it is on the grill so the hose I use for my 20# tank does not have a regulator on it.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
