Tin-bender's avatar
Tin-bender
Safety issue ????
Just bought a new travel trailer and I find that the quick disconnect for the outdoor BBQ is stubbed out in the back of the wheel well subject to possible extreme damage in the case of a blow out.
I know some would say to travel with the tanks shut off and there would be no problem, but that is not what I do.... I think that the best solution is to remove it and cap it off.
Just seems like a strange thing for a manufacture to do based on the history of trailer tires.
Any thoughts on this situation out there.
Tinbender
  • You worry too much. There is a flow limiting device installed on the propane system. In the event you had a blowout that wrecked the propane piping, you'd only get about enough propane leakage to smell and maybe have a minor flame that simply couldn't stay lit while the vehcile is moving.
    Under no circumstances have I read or heard of this actually causing any problems for RVers in blowout situations.
  • Agreed. I would remove the stub, cap it and carry a spare propane tank or put a T in the front before the regulator by the tanks to grill off of.
    Tinbender
    Cap it off permanently and use a separate 5 gal. propane tank. Blow outs / defective tires are going to happen to every RVer sooner or later. 2 of my tire blow outs did about $1200 damage each time:(
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 05, 2026
