BadgerMcAdams's avatar
Mar 15, 2018
safety question concerning a hitch assembly
The DW and I have a 2017 Ram 1500 that will be our TV. It has the 5.7 hemi, and the complete tow package (brake controller, connections, HD hitch for the truck, etc). It will tow the trailer we are looking at, so that isn't the problem. Just laying the ground work.
The other day she was rear-ended on the way home from work. She is a bit sore but otherwise okay. The truck suffered a slightly bent bumper and a scuffed tailgate. The other vehicle (GMC Denali) met our Trailer Hitch. They did not become friends. The hitch took the brunt of the impact but appears to be completely undamaged.
My question. When we take it in to have it checked for the insurance claim, should we insist that the hitch be closely inspected and or replaced? I have looked under the truck and see no damage, but then I am not taking anything apart to check it either. I am sure they will check for a bent frame, damage, etc...but as we will be pulling a trailer with this truck eventually, I am concerned about the hitch's integrity now.
I am of the mind to tell them to replace the entire hitch assembly, regardless of whether they feel it might be good or not. IF they decide that it is in safe condition and won't replace it, I will insist that the underwriters give me a signed notarized statement indicating that the hitch meets DOT safety standards and that there is absolutely no damage to the hitch that will cause it to fail during normal usage. (of course, they will probably tell me to go pack sand too...but that will be another story)
So am I being over cautious? I know that the hitches are designed to meet DOT standards for towing and such, but they are also not designed to act as a bumper in an accident either.
  • BarneyS wrote:
    Were it my truck I would insist on a new hitch. Those things take too many forces in all different directions to take a chance on one that has been hit in an accident.
    Barney
    This is good advice...I sure wouldn't chance it. Too much at stake.
  • Absolutely get the hitch inspected and if damaged, it should be restored to it's original condition, no other alternatives there. Make it perfectly clear to the "shop" that you tow a trailer. Not only is YOUR safety paramount, but so is everyone else's on the road around you.
    If the hitch cannot be fixed, replaced, restored to it's original condition, then it's time to dispute the functionality of the truck with your insurance company as it cannot be used then, for the purpose it was originally intended ... towing!
  • Were it my truck I would insist on a new hitch. Those things take too many forces in all different directions to take a chance on one that has been hit in an accident.
    Barney
  • Glad your wife is OK.
    If the 1/2 ton is like the HD trucks, the hitch assembly is actually a cross member. I would check it over very closely for damage. They are designed to rotate upward in a crash. You should be able to put a drawbar in it and see if that has happened at all. I would also inspect welds for cracks.
    And yes, have the shop check it very closely too.
    Good luck,
    Scott
