CamperWill's avatar
CamperWill
Sealing holes in underbelly
Hey all, recently purchased a Wildwood 30QBSS and upon inspection of the underbelly it looks like there are a few areas that need to be sealed up to prevent rodents from getting in. The underbelly is that tarp-like material and there is also a decent size hole in the plastic surrounding the fresh water tank for the low point drain.
Any suggestions on what to patch these holes with? The holes in the underbelly material are roughly 1-2" but the holy in the tank surround is closer to 5-6".
  • rhagfo's avatar
    rhagfo
    Explorer III
    TenOC wrote:
    I would use a can of expanding foam insulation -- might make the hole smaller with tape first. I think any type of tape will come loose in the 70 MPH wind under the RV. There are YouTube video of people using 3M type spray adhesive to stick fiber back in place. Google for repairing leak in black/gray water holding tank.
    Gorilla tape will work on the fabric, black foam is best used to seal around objects going through the Corrplast underbelly enclosure.
  • I would use a can of expanding foam insulation -- might make the hole smaller with tape first. I think any type of tape will come loose in the 70 MPH wind under the RV. There are YouTube video of people using 3M type spray adhesive to stick fiber back in place. Google for repairing leak in black/gray water holding tank.
  • Lwiddis wrote:
    "Any suggestions..."
    Yup. Looking under the RV BEFORE taking delivery, not after.
    Great suggestion.. Didn't really feel like completely crawling under the RV that day since it was down pouring, a quick check around the perimeter looked fine. Additionally I think we all know there is ALWAYS something that needs to be taken care of with RVs.. something minor like this and other fixes isn't worth dragging it into the shop for.
  • No personal experience, but I've been told that Gorilla Tape works well for that type of patch.
  • "Any suggestions..."
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 08, 2025
