DallasSteve's avatar
DallasSteve
Nomad II
Feb 23, 2018
Selecting A Motorhome With Enough Tow Capacity
As I begin my search for a motorhome I am finding it difficult to determine the towing capacity relative to the vehicle I will tow behind it. My situation is that my vehicle cannot be flat towed so I plan to put it on a trailer (in spite of cautions I have read about that decision). The vehicle (a 2018 Subaru Crosstrek) weighs about 3,200 pounds. An open trailer (which I have not bought yet) weighs 1,500 to 2,000 pounds based on some Internet searches I have made. So I need tow capacity in the range of 5,000 pounds. I should add that I want a motorhome with a Ford gas engine, not diesel, and it will be about 35 feet long (which is pushing the limits of a regular Class C).
I've searched some posts here and other websites and I see that the basic formula is multi-faceted. Here's what I think I have learned:
1 - Subtract the loaded weight of the motorhome from its GCWR. That is one limit.
2 - Check that the hitch rating is also more than the 5,000 pounds needed.
3 - Check that the weight on the rear axle plus the tongue weight of the trailer is less than the GAWR for the rear axle.
Have I got that right? So as I look at ads for Class A and Class C vehicles sometimes I see the GCWR and the GVWR, but not very often the hitch rating. Questions:
How can I determine if the motorhome in the ad has the tow capacity I need?
Do gas Class A RVs have higher towing capacities in general than gas Class C RVs?
Is there a specific brand/model you recommend? I read one poster saying that Forest River units with Ford E450 all have a hitch rating of 7,500#. That sounds like what I need, but I would probably prefer most Class A layouts.
Thanks for your help.
Steve
