BurbMan
May 31, 2022Explorer III
The page 316 of the owner's manual for the 2022 Escape says ONLY the hybrid can be towed 4-down and it's very easy to do: simply go into the onboard menu and select "Neutral Tow". No other equipment like lube pump or driveshaft disconnect required.
Interesting that hybrid has this feature but the gas-only AWD and FWD versions say no towing ever unless on a full trailer. The hybrid must some sort of transfer case that combines gas and electric power that you can select into a neutral position like on 4WD trucks.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
