travelnutz wrote:
Mocoondo,
A lot of exaggerating in your post!
However, we and the septic pumping service did notice a slight slow down last year as he had us repeatedly flush all 3 toilets over and over with the cold water on full blast in the laundry tub to see if the tank level would rise which happens when the drainfield is clogging. No soggy ground and just a small increase in tank level.
Apparently exaggerating is contagious.
A typical tank has two compartments, primary and secondary with one inlet and one outlet port. The liquid (and other 'stuff') pours into the primary chamber, as it does the already full chamber spills an equal amount of liquid over the baffle into the secondary chamber in an extremely thin layer over a large flat baffle meant to keep solids in the primary chamber. As the liquid enters the secondary chamber, which is also full to the spill point, it again displaces an equal amount of liquid which then pours out into the tile field.
There is only one way for the liquid in a septic tank to rise,
even a little bit, is if the outfall pipe is clogged.
A septic system is designed to take no more than about 10 to 12 gallons in a single shot, there is no way 80 or 100 gallons could be safe to do. Not even once.
As for your health board, there's lots of things in this world that you don't need a permit for, doesn't make them wise to do.
