BarneyS
Feb 04, 2016Nomad
Often stiction because of slight sideways pressure via placement of the tongue on the Sherline will cause erroneous readings. I would take several readings, moving the scale ever so slightly between them, and then average the readings. The height of the tongue will make the reading vary also. Make sure you measure at the same height each time - preferably when the trailer is as level as you can get it.
Barney
Barney
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
