KD4UPL
May 17, 2018Explorer II
Since you don't say what inverter you have nobody here knows really what to tell you.
Likley the answer is yes, leave the inverter on and it will act as a UPS. If you have a Magnum, Xantrex, Outback, or something similar it should switch fast enough that your TV and dish won't re-boot.
You should not ever have the inverter output and the shore power hooked to the same outlets but no factory set up would be done that way. Only if a DIY guy hooked something up himself might you have this problem.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 11, 2026
