georgelesley
May 18, 2018Explorer
KD4UPL wrote:
Since you don't say what inverter you have nobody here knows really what to tell you.
Likley the answer is yes, leave the inverter on and it will act as a UPS. If you have a Magnum, Xantrex, Outback, or something similar it should switch fast enough that your TV and dish won't re-boot.
You should not ever have the inverter output and the shore power hooked to the same outlets but no factory set up would be done that way. Only if a DIY guy hooked something up himself might you have this problem.
We have a Xantrex 1000W installed by Winnebago it powers some outlets but not all.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Dec 14, 2014
