time2roll
May 19, 2018Nomad
It can take time to reboot, especially a satellite to get a signal after interruption.
Are you sure when the tv came back on it was on inverter power vs the EMS allowing utility power again?
Depending on how your inverter is wired you could just cut utility power when voltage is running low and run full time on inverter. If it just runs some outlets you can probably turn off the breaker that feeds that branch circuit. This will avoid the reboot.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Dec 14, 2014
