Tonijim's avatar
Tonijim
Shout Out to Ready Brake Brute/Night Shift Auto
This is a shout out for the makers of the Ready Brake Brute tow hitch with supplemental braking system - Night Shift Auto of Iola KS.
We have used the Ready Brake Brute since 2004, and have been very pleased with its performance with two Class C's and our Saturn.
When we felt that the actuator arm and assembly seemed to be slower to respond and that it might be affecting braking, we contacted Night Shift Auto. Their helpful staff said that, despite the vintage of our system, they took their lifetime warranty seriously - "like Craftsman tools," he said, requiring only that we send the unit to them at our expense. They would service the unit at no cost and return it to us postpaid.
We sent the unit and they performed evaluation and maintenance service, replacing old parts with brand new at no cost. The unit was returned to us today.
It has been some time since we have seen service like this.
THANK YOU NIGHT SHIFT AUTO!
Jim
  • Silver Eagle 9452 wrote:
    I guess i need to get ahold of the ready brake guys..have towed my 3/4 ton crew cab long bed about 1200 miles , behind the coach and dont think it ever activated have slamed on the brakes a time or to after puting a little grease around the part that supposed to move and only get a 16th of a inch of movement...have every thing hooked up leval so no bind in it....anybody have any ideas on it? truck is sure heavy enough it ought to be pushing it in..
    Your problem may be as simple to fix just by adjusting the brake actuator cable. If too tight, brakes will actuate too soon; if to loose, the brakes will actuate too late. The adjusting procedure should have came with your installation instructions; if not look on Ready Brake's website or give them a call.
    Ray
  • FIRE UP wrote:
    Gents.
    This is good news for many of you. I however, called NSA for a question on mine and, all they said was, "send it in and, we'll rebuild it for you at your cost and then, send it back to you". I thought I'd heard before that they did lifetime warranty but, I guess not in my case.
    You see, I think my actuator is seriously WEAK! That is, if I push o the actuator lever on mine, I can push it all the way forward with just one hand. I walked up to a friends the other day and, I can't budge it one micro inch. He says he has to put a pipe on his to be able to move it.
    So, I think I'm prematurely wearing the brakes out on our toad due to a really weak return spring and, hydraulic section in that actuator. I'll call them again when I return home from this trip we're presently on. Glad the OP got great service from them.
    Scott
    Mine was not as bad as yours. But something similar was going on. Neither the old or rebuilt parts could be actuated by hand. I would call and talk to Todd. He is the person that took care of me when I stopped at the plant.
  • Gents.
    Scott
  • I guess i need to get ahold of the ready brake guys..have towed my 3/4 ton crew cab long bed about 1200 miles , behind the coach and dont think it ever activated have slamed on the brakes a time or to after puting a little grease around the part that supposed to move and only get a 16th of a inch of movement...have every thing hooked up leval so no bind in it....anybody have any ideas on it? truck is sure heavy enough it ought to be pushing it in..
  • Same here. We stopped at NSA's place on our way home from CA last April.
    In 1 1/2 hours tow bar was removed, inspected repaired and installed back on RV and car. Brakes were coming on sooner than I thought they should. Braking actuator was replaced along with a couple of other parts. I am happy with operation now.
    To top that off we needed a place to stay for the night. There turned out to be a Passport America park in town.
