- gmc6000Explorervinegar works wonders for the water spots.
- tbredExplorer IIDaily shower spray after last persons shower in morning, soft scrub w/bleach several times throughout season.
- KlueckExplorermagic eraser
- BubbaChrisExplorer
mtrumpet wrote:
We wipe our entire shower down completely after each shower with a micro fiber towel. That helps keep it clean all the time.
X2, except I start with a squeegee
My extra motivation is we store our hamper in the shower. So once it's wiped down we can put the hamper back inside. - fla-gypsyExplorer
xaugievike wrote:
Fantastik. My shower enclosure had recommendations on what to use printed on a sticker. Fantastik and 409 were specifically recommended.
X2 - mtrumpetExplorerWe wipe our entire shower down completely after each shower with a micro fiber towel. That helps keep it clean all the time.
- 2oldmanExplorer IIsos if it's bad, daily shower spray.
- sdianel_-acct_cExplorermake sure it says safe for fiberglass.
- wbwoodExplorerUse whatever you would use at home on your shower.
- DutchmenSportExplorerYou can use automatic dishwasher liquid. It's made to cut through grime as well as water spots and calcium build-up. You might want to dilute it enough with water (as it is usually very thick) so you can use it in a spray bottle. If not, just pour some on a sponge and wipe it on. You'll need to let it sit a while, but it will remove the lime spots wonderfully.
After you clean, get a squeegie and use it every time a shower is taken.
One other tip. After you clean the glass (even the walls), apply a coat of automobile paste wax before using the shower. Buff out the wax clear. Then use a squeegie and you'll always have a very, very clean shower.
I did this more than a year ago on my home shower, and I have not had to clean the glass since. The squeegie takes care of it.
But for your initial cleaning, Automatic Dishwashing Liquid (any brand) works very well.
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 03, 2025
