leeper's avatar
leeper
SHOWER DOMES
I have a 2 piece shower dome, inner and outer. Does any one know what is the purpose of the inner dome? Is it needed?
  • Robin1953 wrote:
    BurbMan wrote:
    ...traps a layer of air that helps insulate.
    I wonder how that stink bug got in between the inner and outer dome in my NEW 2015? My guess it is more cosmetic than functional...JMHO
    Trapping a layer doesn't mean it's perfectly sealed.
    While perfectly sealed is more efficient, it is much harder to accomplish. Even partially sealed will be far more efficient than a single layer.
  • Nutinelse2do wrote:
    I would not be comfortable with a single layer. What if the outer one gets broken or damaged? Just a thought
    Then you have water ingress into the roof (ie: bad thing).
    As others have said, it's about insulation value.
  • The outer dome sits on top of the roof and gets screwed in and sealed. That leaves the insulation and ceiling cavity open to steam and moisture from the shower. The inside dome gets screwed to the interior ceiling and seals the ceiling cavity from moisture. Added benefits as noted above, the inside dome trims out the hole so it looks better from inside, and also traps a layer of air that helps insulate.
  • Besides the answers above, it is used to hide the hole in the roof. Remove it and see if you like the look.
  • I would not be comfortable with a single layer. What if the outer one gets broken or damaged? Just a thought
  • Insulation value with the air layer in between?? That may help keep heat and cold out. The single layer vent covers do not do a very good job of that.
