chipster's avatar
chipster
Sidewinder 5th Airborne
I'm looking at purchasing a 5th wheel toy hauler and this Sidwinder Kingpin seems to me like the way to go with my short box. I like the side winder airborne for these reasons....1. built in shock/airbag 2. ease of hooking up and disconnecting. 3. my hitch will be able to hook up to other trailers if for some reason I have to( No catch plate).
My question is what hitch to I get with this Sidewinder....dual pivoting, are they all adjustable for height height.
I did like the Super Glide but I understand you have to be more in a straight line to hook up and I would have to purchase a Airborne kingpin also to help with the chucking.
Thanks
  • You can be +/-16 degrees to hitch/Unhitch in a conventional manner. You can hitch/unhitch at more severe angles by lifting the hitch plate over the saddle and pinning/unpinning the hitch plate from the saddle.
    But regardles of angle, the pin must be centralized to the receiver. If off too far (left to right) hitching can be a problem.
    But the angular spec is not a big deal at all. And in fact is better for the trailer anyway. Hitching at a severe angle can put a heavy side load impact on the elevator legs. That is never a good idea. As it can cause damage to the elevator legs. A straight on hitch is much better because the thrust is in alignment with the wheel chocks.
  • just talked to Pullrite....have to use capture plate. Guess I could get Pullrite and add airborne kingpin down the road.
    Do you have to be in a straight line when hooking up or unhooking?
  • hammer21661 wrote:
    I think you can lock a super glide if that makes a difference.....
    Not that I can recall, and I can't quickly think of a way you could.
  • I have the superglide with an Airborne. As long as you have the right adapter for the king-pin box it should not be an issue.
    Yes, you can only hitch/unhitch within +/- 16 (?) degrees of center line. While I did (once) hitch the old RBW at 90, it was an unusual situation ( I had gotten parked in, while un-hitched)
  • Keep in mind the Sidewinder moves the pivot point behind the axle, so you lose the stability advantage of a fifth wheel.
  • I think you can lock a super glide if that makes a difference. if not the pullrite super fifth or the reese elite.
