DrewE
Jul 05, 2021Explorer III
Something is keeping the water from getting to the weep holes. Those gaskets do not form a watertight seal; they just "mostly" keep water and general schmutz out of the track. At least on my windows, they're relatively easy to pull out and not too hard to put back in place; and I suspect if you did that you'd find there's a good bit of general debris all around underneath the gasket, and further cleaning it all out would make the window drain properly.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
