renojack's avatar
renojack
Sloppy receiver/shank?
In adjusting my Andersen hitch to accommodate my newer trailer one moun ting hole higher, I noticed what may be slop in the receiver/shank fit. Is slop built into this fit or how much is too much? and how to correct excessive slop? add weld bead to shank? replace the receiver or replace factory hitch for an aftermarket?
Any advice or experience. Maybe a tighter receiver would improve weight transfer.
  • I drilled a hole in the bottom of my hitch and tapped it for a 1/2 inch thread. I screw a short grade 8 bolt in and snug it up. Just do not drill directly under the pin, an inch or two behind the pin works good. I posted this on here before and received a response of how I had weaken my hitch. I guess those 5/8 inch holes in each side don't count. I have done this on the last 4 vehicles I have owned including my MH so my towbar does not move.
  • I shim mine with 2 pcs of 1" wide metal banding strap. I'm thinking about welding a bead on the top 2 corners and then grinding down for a snug fit.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Feb 20, 2026
