GaryS1953's avatar
GaryS1953
Solar panel cable routing
Hi All - I have a small 25'5th wheel to which I am adding solar panels. I've already upgraded my batteries to 2 GC2 6 volts in series. The batteries reside in boxes on a rack under the 5th wheel overhang. I'm trying to figures out the best way to route the wiring. I'm going with an MPPT charge controller which needs to be inside the unit, so obviously the wiring needs to get from the panels to the charge controller, then from there to the batteries. Getting from the charge controller to batteries is relatively easy as I would mount it on the interior wall with the batteries on the other side and just drill a hole for the wiring. The question is how do I get the wiring from the panels to the charge controller? I've seen people talk about going down one of the vent pipes, but those are at the rear of the camper with no easy path to get from there to the front wall. Any ideas? Any help is appreciated.
  • In my sons 5er we went down inside the bedroom closet. Minimum distance to the controller and batteries.
  • westend wrote:
    One thing I never understood was trying to connect modules in series or not spending $$, all in an effort to eliminate buying and installing larger sized wire. I used a lot of 4 AWG welding cable in my 12V system and it is easy and inexpensive to do so. I always figured that I am spending good money on panels, controller,and distribution so why would I lose even 2% because of wire loss.
    Lots of additional variables. For my rig 24V panels provided the most watts, least cost and least footprint/watt. At that time 12V panels would cost more and with the cheaper PWM CC the total cost was only $100 less for 12V panels.
    And I connected them in serial because with bypass diodes it is more shade tolerant than parallel. I used 63' of 10 ga wire for a loss of 0.6% to the CC.
    And I connected them in serial because with bypass diodes it is more shade tolerant than parallel. I used 63' of 10 ga wire for a loss of 0.5% to the CC.
  • Well after reading peoples thoughts the fridge vent seems the most likely spot, but my fridge goes right up to the ceiling, with no cabinet in between. If I feed the wire down will I be able to see/find it behind the fridge at the exterior panel opening? My 5th is so small I do NOT have a basement, and there is the kitchen sink, cabinets, and "living room" between the fridge vent to deal with. If I can get to the wire from the exterior panel opening then I can snake it under the sink and through the cabinets, but there is NO good way that I can think of to get it from there across to the front wall that I have to drill through to get to the batteries which reside on an exterior rack under the 5th wheel overhang.
  • Having re-read Wind River AND CA Traveler's suggestions, I think I may go with that. That way I could go straight down trough the bedroom which is the overhang of the fifth wheel. I don't have a closet in the bedroom, but there is a handy cabinet right there next to the bed where the charge controller could be placed, then just drill a hole through the floor, which would have the wire come out right above the batteries. That would also have the advantage of being the shortest run. I do plan on using large gauge wire, but the shorter the better. Any thoughts? Would there be any problem having the charge controller that close to where we sleep?
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
