GaryS1953's avatar
Mar 07, 2017
Solar panel cable routing
Hi All - I have a small 25'5th wheel to which I am adding solar panels. I've already upgraded my batteries to 2 GC2 6 volts in series. The batteries reside in boxes on a rack under the 5th wheel overhang. I'm trying to figures out the best way to route the wiring. I'm going with an MPPT charge controller which needs to be inside the unit, so obviously the wiring needs to get from the panels to the charge controller, then from there to the batteries. Getting from the charge controller to batteries is relatively easy as I would mount it on the interior wall with the batteries on the other side and just drill a hole for the wiring. The question is how do I get the wiring from the panels to the charge controller? I've seen people talk about going down one of the vent pipes, but those are at the rear of the camper with no easy path to get from there to the front wall. Any ideas? Any help is appreciated.
  • How about something like this: https://www.renogy.com/renogy-cable-entry-housing/
    Amazon may have this item also.
  • Mine goes down the fridge vent, across to the furnace space, through the floor, then forward to the front compartment.
  • The refrigerator chimney ia a good place, you can also use the black or grey tank vent tube area, not in the vent tube but on the side to run the wire in and then place the vent cap with dicore sealant.
    navegator
  • Is it possible to surface run the wire to the controller? That would eliminate any holes in the roof or long pulls inside.
  • How about the frig vent? I went through strain reliefs in the side of the frig vent then out the side of the frig cavity into the cabinet area under the oven and then through the floor. Distance is resistance, make up for it with heavier gauge wire.
Looking for advice before your next adventure? Look no further.25,175 PostsLatest Activity: Nov 09, 2025
